- Joined
- 27 Jan 2008
- Messages
- 24,903
- Reaction score
- 2,877
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I am using a freezer 32 litre as a fridge, using a temperature controller built to brew beer. So set at 4 degrees C and works fine.
However on return from supermarket and filling unit with drinks inside shows 16 degrees not surprising and the motor fires up. But instead of running until at 4 degrees, it cuts out, clearly the built in sensor has reached -10 degrees which I think is what set at, so it seems to reduce temperature in steps.
This is OK for my drinks, but once one hears the fridge or freezer start to cycle one assumes it has reached set temperature with frost free models with circulating fans I am sure it has reached a safe temperature, but what about cheaper not auto defrost types, if loading in a load of food to freeze can it cause existing food to defrost?
We have in the past put loads of fresh products into the chest freezer without considering how it could defrost existing food.
