for the past few weeks i have noticed a really bad smell (almost makes me sick) coming through the shower head with the water (to start with then goes after a while), we have changed the shower head but still the same stale, horrible smell comes through and i dont know why.
the shower is fed from an electric shower pump in the hot water cylinder cupboard in our bedroom. there is a hot pipe from the hot water cylinder to the pump and a cold pipe from the cold water tank in the loft. what could be causing the bad smell? could air be getting into the system somehow?
I assume it could be one of two things.
1) Something has died in the cold water tank in the loft. But the smell doesnt come through the bath taps as the bath cold tap is fed from the same water tank.
2) The filters on the pump need a good clean / changing. The pump has been installed 3 years and i dont think the filters (if there are any) have been cleaned or changed in that time.
Your thoughts and suggestions would be much appreciated.
Cheers
Matt
Cheers
Matt
