I have this run of pipework in our kitchen that we are renovating. It sits in completely the wrong place but we want to utilise it to feed a large 1400 x 600 double rad.
At the moment the pipework comes down from the ceiling goes through the brick wall and into lounge the out the lounge into the hallway to serve 1 radiator! (originally there was another small radiator which has been removed hence why there is a stop cap on the bottom of the pipework)
My plan was to cut it above ceiling run it going left in the image behind the RSJ (there is enough gap for 15mm and expansion) drop down into the recessed wall on the left of the image (which is going to be studed out level with the existing walls) then T'd to serve a radiator on that wall and then on the other part of the T have pipes running to the original connection that runs through wall to the hallway rad, sound ok??
