rebated door lining clearance
10 Feb 2014
Northumberland
Hello i am new to DIY doors and walls so bear with me if question is stupid,
I have bought a rebated door lining to install in a stud wall I am building.
The door will be 27in (686), the casing width total is 33mm, thin section 20mm (13+20 = 33mm).
Anyone know what clearance around the door should I allow for? 3mm on all sides seems to be the suggested clearance for linings with a separate jamb bit and wondered if this was the same for the rebated door type ?
many thanks
its not this lining but very similar
http://www.wickes.co.uk/rebated-softwood-door-casing-106mmx21m/invt/200331/
