Hi guys so im doing a renovation on an old property built in 1904, the house had a lot of issues such as damp and rot and these have been sorted,
I spent a lot of time debating how to reboard it and whether to use dot and dab or battening, but after countless advice not to use dot and dab on walls that have been damp, i have went for battening
I had someone in to patch and level off parts of the walls which had been back to brick either because of damp, or blown plaster, with sand and cement, they didnt do a brilliant job but its taken away the big step from brickwork to plaster its helped
Now im running vertical treated 2x1 battens down the walls, and fixing foil backed boards onto these, but because this house is so old the walls are just bowing and out of line all over the place, im doing my best to try and get them perfect with wedges but im struggling
Im now wondering just how perfect does it have to be???? Because IF i had just went down the patch and re-skim route, the shape of the walls would still be as they are, so surely im improving them slightly?
I just dont want to get to the point of painting and there to be shadows or visable bows in the wall, im new to renovations so maybe being a bit cautious? I dont know
What extent should i be going to on a project like this?
Aslong as once painted the walls look normal im happy.
