I’ve a small dwarf type wall at the end of my garden, backing onto a tarmac type pavement. It is mostly made up of sandstone sections and rubble, with a capping section on top. The capping section is in poor condition in many places, and the sandstone is bulging in places, so I intend to replace it.
My plan is to remove the wall but leave the foundation in place.
Then to rebuild the wall with concrete blocks and coping on top. I thought I would use the blocks on their side, so it would be around 215mm wide, and 3 courses high, coming in at just over 300mm high, plus coping. I then plan to paint it.
Having limited knowledge of building techniques and materials, I have some of questions.
Would the blocks on the ground suffer badly from frost over a few years? Is there a specific type of block that is better for this?
Would the paint be damaged by rising damp on the wall, and have a limited life? Should I put in a membrane to limit this?
Would I reseal the wall to the pavement with some type of bituminous type poured material? Any suggestions to a product for this?
Any help would be much appreciated
