I'm installing a new window in a gable end (BC approved) and have done the inner leaf; have taken down the outer leaf and now want to build back up. I know there are a variety of replacement wall ties on the market, allowing you to insert (some with resin) the tie into the existing inner leaf, and then build up the outer on the tie using standard construction. Can anyone tell me if, however, you can drill/rake out the mortar, say for 50mm in the existing wall and bed in a standard tie using a stiff mix? Sounds too easy, but then again perhaps not?
