I have moved into a house which has a 5m x 3m conservatory at the rear of the property coming off the lounge. The conservatory has a dwarf wall, glass glazing to sides and rear plus polycarb roof.
Planning permission for the conservatory was granted back in '76.
I want to build up the side walls to full height, remove the rear dwarf wall, put in a lintel to expand a 4m opening so I can put in some of those rather fancy folding doors. Also, I want to knock down the wall between the lounge and conservatory to incorporate both rooms into one. I plan to change the old polycarb roof to a flat roof.
The footprint of the conservatory will remain the same so will it be just a case of conforming to Building Regs on the rebuild or will I need to submit another planning application? No doubt I will have to build the side walls again as the foundations don't appear to be that deep according to the original plans.
On investigating the wall between the lounge and conservatory there is what appears to be a full width lintel in place .
I have had a structual engineer to have a look and he thinks itmay be best to submit planning permision again. He sent his quote to me last week at a price of £1460 + VAT!
On phoning the planning dept I've just been told that because I'm not increasing the volume no planning permision would be needed if I put a flat roof on but I would obviously would have to conform to building regs!
A builder has just had a look at the job. Bearing in mind I will remove and demolish the existing conservatory he has quoted me £8200 and that doesn't include the folding doors. I can do the internal fixes, sparks etc.It seems a lot of money to me for building two walls and putting in a lintel and some joists. But perhaps this is todays prices?
Any thoughts on this project gents would be much appreciated however critical!
regards
regards
