The installers!Whats the best thing to use to fill these cracks?
if you are the installer please say so
we are trying to be helpful and the advice above is spot on if you have paid someone to do the job
of course if you have fitted them yourself you will need to pay building control to certify the installation if up to standard
are they internal or external ??
gaps are unusual if the job was done correctly in the first place
do you have any pictures please
yes thats fine
but if you have air flow i would suggest they haven't properly filled the voids fully between the new windows and the wall possibly causing cold spots??
can you prize back any trim easily in the coldest rooms to see if there's a good level off fill??
definatly get them back if theres draughts but heat the room for several days to see how it works out first
trim is added plastic/wooden moldings to cover gaps in the same way architrave around a door fills the gap between door frame and wall
