Recess plumbing in wall
22 Dec 2005
Oxfordshire
Hi All
Is it ok to recess a cold water pipe into a wall (double skin concrete block) and board and plaster over it? If so should it be within trunking?
If it is ok is there anything I should take into account?
Many thanks
Chris
you need to protect it against corrosion with either insulation tape or wrap around felt lagging. if u can let it in enough putting it in a plastic mini trunking is the best option to stop cracking of the plaster & condensation marking the wall.if its in a trunk no need to tape it.
