Recessed Bathroom Cabinet
9 Oct 2012
Surrey
Hi all,
I have a downstairs bathroom with is 1.1m wide by 2.7m long. I'm in the process of re-designing the room and dont want to clutter the room.
I want to build or buy a recessed bathroom cabinet (approx 300mm wide x 600mm high) and fit it into an existing wall.
The wall is an exterior facing wall and I believe it is made of breezer block (2 blocks with a cavity).
What I'd like to do is have a recess cut out in this wall and place a bathroom cabinet inside the recess.
My questions are:
1) Is it safe to do (I will be speaking to a structural engineer to confirm if safe)?
2) Is it possible to get a clean cut out of a wall already in place?
3) What tools would you need to do this?
I don't plan to do the work myself but would have someone come in and do it.
I haven't found much on the net where anyone has tried doing this already, so thoughts would be welcome. I'd like to avoid just mounting the cabinet on the wall as I'm looking to save space and this will make a visual difference.
N[/img]
No, you can't do this really, for a number of reasons. Most importantly is that it will weaken the wall significantly - you would need to put in a lintel. Secondly you will of course lose the insulation effect of the two leaves of brickwork. In short, for a bathroom cabinet, it's not worth it.
