I have a bathroom with those GU10 bulbs that are recessed into the ceiling, held in by spring-loaded clips and hidden in the fitting behind a circle of glass, a rubber ring and another metal spring thing.
Changing the bulbs in these is always a challenge, but they are there and always have been, and I guess they were designed like that to be safe in environments where this is water and steam. That's not to say I have to like them!
Today I was changing two of these and while one went fine, when I pulled the second one out of the ceiling hole, I actually noticed that one wire was not connected - I probably did this while yanking around on it.
I've taken a close look at it, the grey / beige GU10 holder part, and there's no screws for me to get inside the bit where the wire has disconnected... there's nothing to un-tighten and re-tighten, maybe I need to replace the whole thing when this happens?
I just don't know, so I'm hoping someone can advise whether this kind of thing is an easy-peasy repair or whether I need to buy something to replace it - like everything from the back bit down to the GU10 holder, or whole new fitting?
If I did have to replace the fitting... is there a better (easier, newer) type of fitting for this kind of light - recessed GU10 in a bathroom environment?
As always - any input is appreciated. I've added a picture here - excuse my chubby fingers.
