Recessed tube lights in bathroom
11 Feb 2011
London
Hi - I'm trying to find a solution for lighting in my bathroom. I want to avoid overhead lights and instead recess lights into the stud walls. The look I’m trying to go for is long (i.e. 1 meter) vertical recessed units (perhaps fluorescent tubes), across a couple of the walls. Here’s a link to the type of look (though I want longer and clearly suitable for the bathroom): http://www.castlegatelights.co.uk/l...recessed-wall-light-with-silver-finish-p17948
Problem is I cannot find any such units – does anyone know of any that I can use in a bathroom?
Speaking to a retailer just now, the other option is to buy standard fluorescent tubes and reflectors, and then silicon seal glass over them. Alternately, same reflectors but use rated LED strips. But will this be safe?
Any other thoughts?
Thanks..
Sounds like silicone would be a PITA when a bulb or starter failed!
Do you mean LED replacements for fluorescent tubes, or the rolls of LED's - they could work?
