recharging an expansion vessel
1 Jan 2009
Tyne and Wear
Does anyone know whats the best pump to use to recharge an expansion vessel, i wanna try that before i replace the PRV in a heatline boiler.
Surely you should just measure the pressure in the EV, then you know whether it is faulty or not?
If it is faulty, you need a new one. If the air has gone, putting more in won't be a fix. It will go the same way.
