Hi all, I will be fitting a keyclamp style handrail to a raised driveway, I have the following brackets to fix to the walls (6 in total).
The holes for the brackets are 10mm before galvanising and I whilst I originally thought I would use 10mm fixings I think it will be very unlikely that I get all three holes exactly aligned. So I could drill them out bigger but that will obviously remove the galvanising. So I'm thinking I will go with 8mm fixings instead and was considering these two:
Either thunderbolts, which I've never used before and feel a bit sceptical about but they seem to be fit for purpose https://www.multiscrew.com/products...crew-yzp-zinc-hex-head?variant=31351466000431 (or perhaps slightly longer than 100mm and should I use some washers too?)
Or sleeve anchors eg https://www.diydirect.com/heavy-duty-sleeve-anchors-with-hex-bolts-m8-x-100mm-10-pack
Or something else?
Thanks as ever.
Or something else?
Thanks as ever.
