Hi all,
wonder if anyone can help advise on a suitable dirty water pump.
The situation is, we're off mains sewerage, and all our water, including water from the roofs heads through a Klargester sewage treatment plan, and into an old cess pit. This probably has never been cleaned out properly (not sure how to... if anyone has any ideas).
The problem we have, is as all the water is processed in this manner, we need to pump water out of the cess pit to ditches around the farmers fields around, however due to the amount of water, any pumps we use, don't tend to last very long. I'm looking for advise on anyone in a similar situation and can recommend a pump which will last.
Long term (ie next year or two), we're looking to have a new extension built, and get attentuation crates installed in the drive, to handle surface water, which should then significantly reduce the amount of water needing pumping.
Thanks in advance
Tony
Thanks in advance
Tony
