As part of my conversion project I have to replace some skylights in the roof of my industrial building. The existing setup appears to be upside down T shaped rods that carry plate glass approximately 600 x 1800. On the ouside a clip holds the glass down and stops it sliding. Lead flashing is present in abundance, the building is victorian. The roof lights are connected in a strip forming a hole about 6.6 metres wide overall
I'm looking for economical ways of replacing this with something more thermally efficient:
The biggest velux that exists seems to be 1000x1600, and apparently velux do jointing kits that allow them to be combined in strips without a break. This route seems rather more cost effective than I thought, but the veluxes are about £500 each so it's still quite a punch in the nose
Velux have a modular/component system but I haven't been able to get any prices
The more i look at it, the more I realise that it's rather quite like a conservatory roof and I can't see why rooflight companies would charge the earth for what seems to be a very simple construction of T or I shapes supporting glass panels
Might it even be possible to remove the existing glass, drop in replacement double glazed panels and insulate the carrier bars on the inside?
I'm not after these things to open necessarily, but after having quotes from rooflight companies that run into tens of thousands I can't quite believe that installing a row of veluxes would be the most cost effective option.
Does anyone else have any ideas of what I could do to fill the gap with something self supporting (between where it fixes to roof at top and bottom), double glazed and can be made to look heritage enough that it won't ruin the look of the building?
