Currently have an old (20 years plus) Trianco Redfyre Centraljet an indirect vented hot water tank. The boiler is coming to the end of its life and i'm considering options.
House is an old cottage with 9 radiators, 2 bathrooms. One of which has an electric shower and the other has a bath and no shower. It is used as a holiday rental and the amount of people in the house varies from 2 to 8. Therefore hot water use is fairly inconsistent.
At present I have the timer on the immersion to heat HW for the last two hours of the off peak electric and then the boiler heats it on and off during the day.
I probably have 3 options:
1 - combi - but our heating engineer has said this would struggle to keep up with hot water demand if two hot taps are running and we'd only get luke warm water. Really??
2 - new system boiler and keep existing HW immersion. Cheapest option (I guess?) but not so efficient...?
3 - new system boiler and replace immersion with unvented cylinder - would be heated overnight using off peak electric- assume this will be the most expensive option.
Any thoughts/ opinions on the above given the use of the house?
Suggestions for boilers? Can either be internally or external. If internal, has to be wall mounted.
Thanks.
Thanks.
