Hi all,
In my bathroom I am using 12mm tile backer board (cement base I believe) as the background within the shower area. I want to tape and seal the joints and also where the tray will come up against the board. Can any one recommend the best tape and sealer please? I have seen people using No More Leaks tape and Aquaseal so I assume this is fine with cement based board but wanted to check what others use.
Also for the backer board onto the floor is this OK on normal flexible tile adhesive?
