have a dated gas boiler, which heats the central heating AND hot water (works fine BTW).
Unfortunately the flue exits approx. waist height, straight out into the path of my workshop door. Sending hot air (not a bad thing when its cold) and fumes (not a good thing at all!) when it kicks in early evening, if I have said door open.
Its a flat wall with the flue cap poking out.
can I put a 90degree bend on that flue and a length of pipe to get it above workshop height?
what would this exhaust pipe need to be made of? (in particular the 90degree bend)
worried about any back pressure or restriction that such a bend might put on the existing system
TIA
TIA
