Whilst I've got my gates off to fix the motor brackets I might as well try and fix the droop that prevents them closing properly - I just need to remount the top hinge so that it pulls the top in by 5-6mm. Problem is that the mounting bolts are 9mm in diameter so there's going to be some overlap with the holes that are already there
If I fill the holes with dowels what's the chances of being able to drill new STRAIGHT holes that are half in the gate and half in the dowels or is the drill bit likely to wander?
Also what would be the best way to drill the holes, was thinking of getting one of these to help keep things at 90 degrees
https://www.amazon.co.uk/Drill-778400-Drills-Cordl...
Gates are 70mm thick so what sort of drill bit should I be using?
Any advice appreciated!
