My partner has recently had a problem with slow water flow to the cold bath tap in her house (which she now rents out). I dismantled all the pipework close to the tap and found what looked like soggy loft insulation in the base of the tap and behind the aerator. Removing this has not solved the problem.
Pipework is as shown. Flow to hot taps is normal, so the blockage is probably in the elbow that connects copper to plastic, or maybe in the curving plastic pipe that goes under the floorboards, the branch exit from the tee or the short section of pipe to the elbow.
I know how to back flush from the bathroom, but I’m worried that if I do that, the blockage will go the wrong way at the tee and end up in the hot cylinder and affect a lot more taps.
Access at the bathroom end is good, but very difficult in the airing cupboard. The elbow is almost behind the hot water cylinder, and there’s a shower pump and associated pipework (with separate cold feed) filling the space at the side of the cylinder. Accessing the tee/elbow near the bottom of the airing cupboard might be possible, but catching any water if I try and backflush to there would be near impossible.
What’s the professional way to tackle this? I’m on the verge of getting a plumber in, something I’ve never done before (other than for gas).
