Reducing from 22mm to 15mm
16 Apr 2009
Surrey
When fitting a bathroom suite, I tee 22mm pipe to the bath taps and reduced to 15mm to take a feed to the shower.
I do this to ensure the water pressure stays as high as possible for running a bath.
It is often a pain in the arse using 22mm due to lack of space (and cost!) and would have found it much easier to have run it in 15mm.
I know it is a matter of opinion, but is it necessary to use the 22mm or would you reduced it before the run?
cheers
