i have just installed a vanity unit, and these sinks are not normally deep. and the pressure of water from the tap causes alot of splashback.
if i was to reduce the turn of the isolation valves to the hot and cold, i.e put the screw on the valve so its half closed/open will this help restrict the flow of water to the tap - causing less water pressure??
its to much of a job to install a water reducing valve so need another work around..
thanks guys
thanks guys
