Hi folks
I'm looking for some advice on how I can reduce the amount of rain noise I'm getting in the bedroom in my sheet metal roofed extension.
I'm not looking to silence it completely, just reduce it as much as possible (just now it's like sleeping inside a snare drum!)
The sheet roof is attached via wooden purlins to the top of an old felt covered wooden roof, which is itself attached to the wooden beams. The ceiling is 12.5 mm plasterboard screwed to the beams, with Kingspan between the joists.
I can't afford to loose much in the way of height in the room and I'm not too keen to take the ceiling down, so....
* Will putting up another layer of 12.5 mm plasterboard help (I previously double sheeted a wall and put a bead of mastic between the sheets and it seemed to make a difference)?
* Would an acoustic membrane make much of a difference, and is it worth the money?
Thanks in advance for any advice
