Hi All,
I've just changed a 20 year old bathroom extractor (which did a brilliant job) for a nice shiny new 100mm Xpelair model (which doesn't do anything - paintwork will need re-doing to remove black condensation marks after just 3 weeks!)
To try to overcome this, I've now purchased a 150mm Xpelair (might have to put weights on kids when they are in the shower!) The new (solid PVC) extract duct will go vertically from the fan about 400-500mm to the underside of the roof, but the roof outlet only has approx 100mm connection, so I will need to reduce the duct diameter for the final connection to outside.
Is this going to have a detrimental effect on extractor efficiency and noise levels, given that it is a relatively short run?
Also, existing 100mm vent has a condensation trap, which obviously won't fit the new pipe. Again bearing in mind that it's a relatively short run in a never that cold roof space would I get away with just insulating the duct rather than fitting a new condensation trap?
Thanks.
Thanks.
