P
peter1450
Hi Fitted a new redwing shower today. Having a real problem getting the 90 o elbow to stop leaking!
If your not familiar with the unit the said elbow is plastic with a flat rubber sealing washer on the end that feeds into the shower unit itself and a brass nut and olive at the other end.
How tight should it be tightened without risk of stripping the plastic thread and what if any sealant should i be using on either end? Cheers Pete.
