Hi
I have drained down our sealed system CH as we had to remove most of the rads for some building work. The system has two auto air vents, a pressure vessel (obviously), and a bypass at the boiler.
Has anyone got an easy to follow step-by-step procedure for refilling and recommisioning.
I assume I will need to put some new 'fernox protector' in the system - am I right in assuming that this can be injected into the system via the air vent on one of the rads prior to pressuring?
Do I have to follow a procedure for eliminating air in the system when recommisioning? (does this involve opening/closing the boilder bypass?).
thanks in advance
Ian
thanks in advance
Ian
