Back to the old citroen c1 problems.
Had to pull a diesel injector and have various asks
1 the hole it came out of has a carbon build up in it, anything to get the carbon off, done some scraping but would like a chemical if possible to make it squeaky clean. Looked at domestic oven cleaner but they all say don't use on ally. Don't want to buy 25 litres as for a wash any suggestions
2 the injector had a plastic skirt firmly stuck to it, how that's supposed to keep compression pressure back I don't know, however when refitting do you put the skirt in the hole and pass the injector through it or fit the skirt to the injector, if so how high up do you place it
3 the injector is held in place with a forked contraption which a bolt holds to the head. The torque loading shown in the citroen book states 2,5 which I believe is 2,5 newton meters? whatever they may be, this equates to 2lbft of torque, to hold an injector down against engine compression, does this sound right?
