- Joined
- 17 Nov 2006
- Messages
- 18
- Reaction score
- 0
- Country
looking for a bit of advice from the experts, had a new shower enclosure installed last year with a sliding door & fixed panel screen. Discovered last week that water has found a route out & has started to damage the skirting & floor right at the corners where the 2 wall channels meet the tray. Think I've caught it before there was any serious damage, I removed the door & frame last night & discovered that the fitter hadn't run a bead of silicon between the tiles & the wall channels before fixing them, same goes with the tray & the bottom of the frame. Seems to be some conflicting advice out there about whether or not to use silicone in these areas before securing the frame, and obviously I chucked the instructions as soon as we were up & running. My instinct is to run a healthy bead up the tiles & along the front of the tray before fitting the frame, then wipe away the excess that squeezes out, and once that's all cured seal round the outside of the frame where it meets the wall / tray - is this the best plan?
cheers
cheers
