Would appreciate guidance on a DIY job that's new to me...
I'm refurbishing a couple of Crittall windows installed in an outbuilding in the late 1950's. The putty holding the single glass pane into the galvanised steel frame has cracked in many places leaving lots of fine cracks - although the putty (and the glass panes) is/are secure. There are however, three or four gaps where sections of putty (~1 to 3 cm sections) have fallen out.
I'd rather not scrape out and replace all the old putty, which is rock solid, as I might (probably will) break the glass, so, two questions: first, can I use some sort of filler/sealant to fill in the fine cracks within the putty and secondly, are there modern alternatives to linseed-based putty to fill in the missing sections or is linseed-based putty still my best bet for these larger gaps?
The putty and repairs will be repainted.
Thanks in anticipation.
