As part of my fencing 'project', I am to add a small 6' x 6' paved area specifically for the ever pulsating collection of eco bins we have around these parts.
I will be using one side of an existing fence (back garden) which I will then continue to run down the length of the front garden (24 meters ish).
From this run I will take another panel at 90 degrees - almost forming a box (following the existing panel and footpath this will be more like a box pushed to one side - a diamond almost).
I have dug out a couple of inches down (occasionally hitting concrete as there are kerbs running on the side of the footpath) but deeper at the other end as this bit of land ran uphill). I've got it fairly flat and level; questions are:
1: Do I need to slant this slightly for when it rains?
2: Due to the odd diamond shape of this area how would I set the new paving slabs...I'm thinking an awful lot of angle grinding should I follow the sides - it's hardly going to be seen by anyone, merely for storing my bins.
3: I'll need to add polythene to the ground to prevent weeds growing though...?
4: How much of a concrete base would I need to add...an inch or two?
Have a look at this 'fantastic' image done on a high spec piece of software!!:
Hope you can help.
Cheers.
NB
Hope you can help.
Cheers.
NB
