I am after a bit of help deciphering the regs on 1st floor Landing width. From what i have read so far the minimum width is 900mm with pinch points allowed for radiators etc.
I am planning some stairs for a DIY Loft conversion i am doing and trying to work out the maximum (or minimum as may be the case) width i can get away with for the new stair case. To fit within the dormer cheek the new staircase will have to be packed out from the side wall by about 230mm. Currently the landing is 1350mm wide in total but the corridor/walkway past where the ground floor stairs come up from is 750mm wide, so below the specified 900mm on the regs. It is a victorian terrace so the regs didnt apply when it was built. If i add my new staircase going up to the loft and shunt around the stud wall to the adjacent bedroom to preserve the current 750mm gap at all points would this be fine?
