Regularly having to bleed towel radiator
5 Dec 2003
I fitted a towel radiator on my bathroom in the summer, which is connected to my central heating system. I bled the system once I refilled it, but it's only since October that the system has been running on a regular basis. I find that I am bleeding this radiator on a weekly basis, because the top rung is colder (marginally) than the others.
Is this a common problem related to the design of these radiators?
Could it be because this radiator has the highest point of the central heating system, so air bubbles elswhere are making their way to it?
Or do I have a leak in my pipework which is sucking in air?
I don't get much air out of this radiator when I bleed it, but I'm concerned that it is the symptom of a bigger problem.
I am grateful in advance for any help.
Huw
Yer bigger problem is corrosion.
Fe (iron rads) + H2O => FeO (rust) + H2 (hydrogen)
It produces hydrogen, which collects at the highest point. You need to add a corrosion inhibitor. Use either Fernox MB-1 or Sentinel X100. If you have a header tank then turn off its supply, let out enough water from a drain point to empty it, then add the elixir and allow to refill as normal.
If it's a sealed sytem you have to inject the stuff or pour it into a towel rail or radiator which has a convenient plug at the top.
If you need the injecting type for a seaed system, this is available as a cartridge which screws into the radiator bleed valve. About £25 form plumbers merchants.
Thanks again, but my towel rad has openings in the top. I thought I'd also desludge my system as well. So have been out and bought the relevant Sentinel products.
Huw
