- Joined
- 11 Sep 2007
- Messages
- 827
- Reaction score
- 6
- Country
I use a 47kg propane gas bottle to feed the gas hob of my cooker.
Just had to swap the hose from the just emptied propane tank to a new one but there seems to be a small leak where the regulator screws into the propane tank's outlet. It wasn't leaking when on the old tank so I assume that corrosion has taken place somewhere on the regulator's thread, or something similar ?
Anyhow, I guess a replacement regulator (plus hose as the old one is pretty old but still intact) is the best solution?
If so, I guess I need a regulator rated at 37mb? I can barely read the printing on the old regulator, it says 37mb I think (the '3' may be a '5' but it looks unlikely). I guess 37mb is the norm for a 47kg tank?
Also, about the pipe which leads leads to my gas hob that the regulator hose connects to - mine is 10mm width but a lot of the kits I find on Amazon have a hose with an internal ID of 8mm - is this normal in the sense that the smaller internal ID of the hose ensures a tighter fit on the pipe? (plus hose clips of course)?
I'm thinking of buying this one:
HG Propane Regulator 1m Hose Kit Fits Calor Gas & Flogas screw in red cylinders : Amazon.co.uk: Garden & Outdoors
HG Propane Regulator 1m Hose Kit Fits Calor Gas & Flogas screw in red cylinders: HG Propane Regulator 1m Hose Kit Fits Calor Gas & Flogas screw in red cylinders: Amazon.co.uk: Garden & Outdoors
www.amazon.co.uk
