Reillo burner problem
21 Dec 2009
Hampshire
Hi
I have a Reillo RDB burner in a Warmflow boiler which has started to malfunction in that it doesn't light up and the lockout light comes on.
I believe myself to be a reasonably competant engineer and have regularly serviced the boiler myself but this time I am unsure what to do next.
There is definitely oil coming from the tank and the nozzle appears to be very damp with oil.
I cannot see any spark at the electrodes within the 12 seconds lighting cycle so I assume that the problem is due to lack of spark rather than lack of oil.
There appears to be about 1000 ohms between the electrodes so at least the secondary of the ignition transformer is OK. There appears to be an infinite resistance between the electrodes and ground.
Electrode spacing is OK (4mm between each and 2.5mm from the nozzle).
The photcell appears to be clean (but I assume that a failure here would probably cause a shutdown after starting up).
Pump coil is about 100 ohms and I can measure some voltage across it (not sure if AC or DC during the startup phase).
I'm tempted to say that the control box has gone west on me but can anyone offer any suggestions as to how to verify this or what else might be wrong ?
Ron Bowater
