Reinforced Concrete Breaking
8 Apr 2016
Hi
I have just took down a concrete coal house, consisting of 5 sides (inc top) of reinforced concrete slabs which were bolted together
I will be ordering a rubble\hardcore only skip shortly and would like to put them in once the rebar is out
Any advise on breaking them up?
Will a sledgehammer do if they are unsupported (stone under one end so its elevated and just wail on it :) )
Thanks, Got an SDS drill
Might give that a try to loosen it up
Yes I should have said SDS, I used the SDS chisel bit that came with it, worked fine.
Your chisel bit will get blunt, use a grind wheel on a drill to re-sharpen it.
just belt them with a lump hammer or sledge.
once you can lift them pop in wheel barrow and skip it.
