For several reasons, my computer is, I beleive, due for a re-format and "start again". I have loads of programs on it that I've only used a handful of times and am never likely to use again, and I know that uninstalling them will still leave "odds and ends" around the place. It's also slowed down quite a bit and become a bit unstable, despite my religious spy and ad-ware checking and removal.
Now here's the issue:
I formatted once before and re-installed XP, which all went perfectly apart from one thing. Having removed (or so I thought) all the partitions and set it up again, it worked just lovely, except that now when you turn it on it comes up with a menu asking me which operating system I would like to start - both options are XP and the second one doesn't work or do anything. It's been like this for a while and it's really nothing more than a niggle, but I would like to know what my error was to avoid the potential (I assume) of ending up with 3 options once I've done it again.
Incidentally, when starting with the "normal" first option, no other partition or anything is visible within windows. Is it a "phantom" problem, and can i have instructions please for a completely "clean" install?
Will be using proper licensed XP disk that came with the computer (Dell).
