Relaying porcelain slabs
27 Aug 2024
Hi all.
I need to lift and relay my porcelain slabs patio area.
I'm going to use a 5:1 sand/cement mix on a full 50mm bed and also prime the back of the slabs with slurry.
Is just normal Blue Circle cement the correct one to use?
Also what slurry/SBR do you recommend?
Cheers
Prime with the correct product from the builders merchants and 3:1 sand cement bed.
