Hello
This topic thread is to do with the (un)reliability of using alarm communicators that use your a normal landlines to notify homeowners of alarm events via SMS messaging.
This topic evolved from this original thread which was initially posted regarding how to connect he communicator to the panel and then evolved into troubleshooting SMS reliability issues.
Some fantastic help and contribution from key users: @secureiam @sparkymarka @Paulj48
Given the subject has moved from installation to reliability I decided to separate the two topics.
Back story:
I recently purchased and installed the Texecom prem elite 48 panel which came as a bundle with a standard Texe keypad and Com2400 communicator.
Considering all factors: property type, lifestyle, proximity to many good neighbors, and budget... our risk profile is low so exploring the use of this communicator in the bundle is ok with us.
I liked the idea of the Com2400 because not only would I get a notification via mobile of alarms, it would give you more details such as which zone(s) have triggered and I also like the idea of setting up arm/disarm notifications while I am on holiday and left the keys with a neighbors.
I installed the alarm system and it all works really well except the SMS notifications.
Thanks to the support on this forum we checked a wide range of things (from settings to phone logs with my telco provider) as well as getting a telecom mate to check my phone network.
Everything on my side of the equation is working but something along the chain beyond my house is not.
The primary SMS centre programmed into the digi is the normal Vodafone number ending 993.
Initial tests showed the following stats:
The alarm was set to notify me of arm/disarm, alarm, and priority alarm events.
28 of these occurred over the test period.
7 failed to reach either of our mobile phones.
I am now running new set of tests where the primary sms centre is still Voda and secondary centre is a service called OpenTAP (which uses a 070 personal number which costs more).
It is too soon to provide an answer on this test but so far it has shown interesting results in that the 6 events so far: one event stood out when voda "partially" failed to notify us, so the digi reverted to OpenTAP and that worked. When I say partially, I did get the voda SMS but my wife did not, but the system moved onto the back up service and I ended up getting two SMS in total and my wife one sms. I thought that was clever as I didn't think the TAP SMS protocols were designed to handle partial acknowledgements. (clearly I'm no expert)
I will report back once we have done the test against more events.
My aim is not to prove SMS as a 100% system, it simply isn't! But I hope we can prove what level of reliability can be achieved and hope the results will prove useful to others.
If anyone else has any test results and stats they can share then please post here.
Thank you
Back story:
Thank you
