- Joined
- 19 Jun 2023
- Messages
- 1
- Reaction score
- 0
- Country
I need to have my swimming pool heater relocated by around 20 metres from its current position, along with the circulation pump and a timeclock. At present the Heat Pump has its own 32A feed direct from Fuse Box and the Circulation Pump runs off a separate feed.
I have removed a Dehum unit which was in the pool house supplied by a 16A feed (2.5mm wire). This is a few meters from the new location of the Heat Pump
I was wondering whether I could join the existing 6mm armoured cable to the 2.5mm armoured cable, de-rate the supply to 20A, and finally extend the existing cable to the Heat Pump and Circulation pump. I estimate the total run from box to heat pump to be less than 50M. Total load is 3.3KW for Heat Pump/Circulation pump.
I know the cleaner solution would be to run the 32A cable all the way but I was wanted to know if there was anything I need to consider if I go the other route? All the work would carried out by a qualified electrician.
Finally do I need building regs if I am relocating?
