Hi.. First post after weeks of lurking, so please be nice to the newbie!
I want to relocate my CH programmer/timer from the back of my first floor airing cupboard to room immediately below.
It is currently connected via 2 3-core flexes to the wiring centre which in turn is connected to a dodgy looking 3-pin socket in the airing cupboard, fused at (I think) 3 amps.
What size cable should I use for the drop to the new location? I assume 2.5mm T&E ( x 2 ) but anything smaller would be a bonus as it would be easier to run -- and the flex currently there - albeit for the very short 1 metre run - looks much smaller.
In case it's useful, info to help with answers:
- Access for a cable run is straight forward & approx 3-4 metres.
- The programmer/timer is a modern (honeywell) with standard backplate
- I'd also change to pick up power for the programmer / CH from the new location rather than the current dodgy looking 3pin which will have one of those safety 1-pin cover things put in so that it's out of use, pending an electrician removing it completely when the CU is changed next year - but I still need both cables as I'll have to take the unswitched supply back up to the CH wiring centre (& on to the boiler etc).
- The new supply connection will be switched FCU with same fuse rating as current plugtop.
Thanks!
Thanks!
