Relocating radiator to fit a new Vertical designer one.
18 Feb 2014
Cumbria
Hello, Please help me out! Thanks in advance
THE JOB:
I am removing a standard horizontal radiator, and moving the pipes 2m to the right to install a new vertical 'designer' radiator.
PIPES LOCATION:
The pipes in my house run 3" above the skirting board behind the plasterboard
(perfectly horizontal return pipe alligned above the flow) They are 10mm copper pipes.
PROBLEM:
My radiator and TRV valves are all 15mm and the house pipes are all 10mm. I don't have a pipe bender so want to work with 10mm plastic which I have lots spare in the garage.
QUESTION:
How do I plumb the pipes up into my radiator? What parts do I need to get the correct elbows etc. Please see the below link for photograph, and the other to see an example of the radiator fitted.
milano-aruba-drw009-white-vertical-designer-radiator-1600mm-x-590mm-double-panel-cutout.jpg
[/img][/b]
You want your pipes exiting the wall exactly as your image.
You can use a reducing set or soldered end feed reducer. Some wall tracking needed and a small pipe bender to make it professional.
I'd bend those into place from where they sit. No cutting needed.
15mm will look better though exiting the wall and insulated.
