Hi everyone.
I know this topic has been up before (c2010) but it doesn't seem to have been solved and I wondered if anyone has had the same thing and fixed it.
It may well be common only to the Remeha Avanta combination boilers so perhaps is a little obscure. My main concern is that this phenomena (booming on ignition) will one day cause an explosion that could cause harm and/or damage.
Because of its intermittent nature the cause of the 'Booming' has evaded all that have attempted a repair, both the manufacturers agents and other gas safe engineers.
If I could afford it I would rip the damn thing off the wall and throw it as far as I could.
It did happen once when the front panel was off and you could see the gas valve actually shake and vibrate, it's a bit scary, it really booms loud!
The whole episode will only last a second or two, as long as it takes to fire up. My own instinct is that unburnt flu gas residual somehow throws off the correct air/full ratio and incorrect initial combustion occurs, But How? The flue is oem and fitted correctly!
Any body fixed this problem please?
Thanks.
Thanks.
