- Joined
- 7 Jul 2020
- Messages
- 8
- Reaction score
- 0
- Country
Hi all.
Boiler's 10 years old - it's in fairly good condition but I don't think it's been serviced much (we bought the house 3 years ago)
Originally threw up an E-7 error code when running a bath.
Central heating works without a hitch. It's only when we run a hot water taps - both the up or downstairs one.
Originally I looked up the code in the manual and it's a flow/pump error, I took the boiler cover off and replaced the pump head and that didn't fix the issue - I don't know boilers, and frankly find them intimidating so at that point we decided to get an engineer in.
He's re-pressurised the expansion vessel, replaced the dhw heat exchanger and the diverter but it hasn't worked. When running hot water from the tap the valve starts fluctuating wildly and you can hear it sputtering, banging and knocking and air coming out of the valve on the top before it throws up the same E-7 error.
We got him to fit a magnaclean pro2 when he did the repair. He's put the MC3+ cleaning fluid in and we've been running the central heating through a single rad to try and shift any residue from the boiler chemically that might be built up. We did manage to run a full bath later that evening so it might be helping - but then the boiler failed again afterwards. This doesn't seem like a proper solution, we're going to keep trying for a day or so to maybe shift what's in there. The magnaclean is picking up a fair bit of sludge but frankly I'm not hopeful this is a long term solution.
I'm just asking for advice really, or for any suggestions. I'm worried we've already totted up an invoice for 600 quid with the filter/replacement parts/labour and i don't want to throw good money after bad. He said it might be the primary heat exchanger - but surely because the central heating is working fine it shouldn't be that??
Also I should say we're doing work on the house, a different plumber has moved the hot water taps upstairs and we've had a rad on and off the wall a few times over the past few months. I don't think any of this is relevant but just in case that might help any diagnosis at all?
