I have a problem with the following boiler and was wondering if someone could shed some light on it:
Its a Remeha Avanta 28C.
The hot water works fine all the time.
When the central heating is turned on the heaters will get warm perfectly fine.
However when the hot water tap is used the heaters will then go cold until the hot water is turned off and then they will warm up again.
The expansion vessel was found to be faulty and has been replaced.
Any ideas would be appreciated.
Thanks.
Thanks.
