Hi
I have an automatic gate which is wired to a switched FCU indoors on a spur from the downstairs ring. The gate has a manual open/shut button for postmen etc during the day, as well as the usual gate remotes on our key rings.
Ideally I would like to power down the gate at night so that it doesn't work and remains locked. The simplest and easiest way to do this is to switch off the FCU, but it is not particularly accessible behind furniture etc.
I was wondering if anyone has ever come across a remote controlled FCU or similar that I could replace the existing normal one with. You can get remote sockets and remote light switches, but I've never seen a remote FCU. I could in theory modify the whole thing and wire it via a 3-pin plug into a remote controlled socket, but it would look a bit Heath Robinson.
Any help gratefully received
