Remote key pad Veritas 8 Panel
27 Feb 2015
Yorkshire
I have just installed a replacement Veritas 8 panel, no problem with installation however the remote key pad does not bleep time down when alarm is being set from it, but there are audible bleeps when 4 digit user code is being inputted. I have reprogrammed main panel to use old sounds but this make no difference. There are only four wires to remote, I have checked and these are connected correctly, I have also adjusted the pot inside panel but this makes absolutely no difference. With defunct panel I did get audible bleeps but these were very quiet, there was nothing I could do to increase volume.
Before I buy a new remote key pad would be grateful for any help/advice/suggestions.
Many thanks for reading this
Is it a onboard with an extra keypad or blank endstation and keypad ? Is it a new keypad on a old panel or new pcb on old keypad ?
Hi sparkymarka
The main panel is new, a direct replacement for the old panel, Veritas 8 zone with on board key pad. The remote keypad is the one that's been installed for many years, it's this remote that's not working correctly
That all seems ok , probably new keypad needed I've had keypads not give out entry tones when it's very old pcb with new keypads
volume control on main unit pcb?
unfortunately there is the odd quirk in compatibility
Thank you for your response, I've ordered a new unit, should be here tomorrow, take it that the pot on original unit has different resistance to current models?
no idea to be honest and but the pot is just the internal panel speaker I believe
