pointless squabbling has been removed from this thread
Hello, I tried this in the automation section but didn't have much response. It doesn't seem too lively in there at the moment.
In my kitchen I have a run of units with undercabinet lighting fed from the lighting circuit with a dedicated switch on the wall. I also have a dresser unit which I intend to fit the same LED strip lighting to.
I have easy access to the feed cable into the transformer (or whatever you want to call it) for the under cabinet lights.
What I'd like to do is have the LED's on the dresser plugged into a wall socket via a 'smart' plug which triggers when the under cabinet lights are switched onl. I.e. they all come on at once. I was hoping there was something I could wire into the undercabinet feed which would act as a trigger that was received by a remote plug / socket interface - but I can't find such a thing.
Any ideas if there is something 'off the shelf' which I could use?
