I have a MDF panel which has been ruined by water getting into it from the bottom. I would like to fit some plywood to the frame and then cover in some wall tiles which I have spare.
The bath only has one side panel as it sits between two walls (and back wall). As I imagine the panel will be quite heavy to remove once tiled can anyone offer any advise as to how this can be fixed and also removed when necessary.
I thought about using magnetic catches as the most of the wieght will be taken by the panel resting on the floor. Should I also silicone round the outside of the panels once grouted?
Any advice would be appreciated.
Thanks.
Thanks.
